Enables UDP echo server support.
vrid | Specifies the VR or VRF. |
port | Specifies the UDP port. |
Disabled.
UDP echo packets are used to measure the transit time for data between the transmitting and receiving ends.
The following example enables UDP echo server support:
enable udp-echo-server
This command was first available in ExtremeXOS 11.0.
